SmartSDR 2.10.0 upgrade issue
Anyone with a 6400M getting an error message when attempting to install v2.10.0? on the radio side, not windows. A problem with Maestro andnot being enough disk space to do the upgrade.
regards
Tim, VK6EI.
Hi Tim, this is a known problem. There us a "fix" release, 2.2.2 that will cure the issue and allow you to load 2.10.0.
Run the 2.2.2 upgrade. It will fail at some point. Shut down and restart the radio, then upgrade to 2.10.0.
The 2.2.2 upgrade will clean up space on the tablet in the radio. The 2.10.0 upgrade has a patch to prevent the issue of the memory filling up in the future.
Thank you gents,
apologies for the late reply, had to get to be in front of the radio again to get the chance to do as suggested.
Worked like a charm, thank you both very much. Much appreciated.
Tim, VK6EI.
- 653 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
