any one use rea modulation ?
hi
is any one use rea modulation with the flex 6700 ?
any comment ?
vy 73 elan ea5iwt/dl9fcc
Hi Elan... you've posted this in the Flea Market.... did you mean Community Topics???
and what is REA Modulation??? Haven't heard of that before.
okay sorry I move it
Hi Elan, it looks like that is just a modulation monitor for AM. It won't work on SSB. The Flex 6000 series radios won't modulate more than 100 % in AM, so I am not sure what value this monitor really brings. If you wanted to operate with reduced, or no carrier (DSB), then it might help you to see what is going on.
I use an REA modulation monitor every day with my 6500 on AM (antique modulation).
The Flex certainly will modulate in excess of 100 % in the positive direction. It easily goes to 140 % in fact.
It will NOT overmodulate in the negative direction, fortunately. There should be no distortion from excessive negative modulation.
The caution is to NOT overdrive your amplifier if you are using one. I barely use 3 watts carrier (12 Watts PEP) to drive my Mercury III s amp just to be sure. The output peaks at about 1 KW give or take.
The Flex is a GREAT AM rig !!! 73 All, Jim KD1I
hello
thank you kind for the answer btw yes it is only AM no ssb I use to have it many years a go o n flex 5000
was not sure if it will work with the 6000 well interesting btw Jim
Ithere is some nice Group on AM ON 28Mhz are this group still there ?
vy 73 elan ea5iwt/g0uut
- 633 The Flea Market
- 129 SmartSDR+
- 195 DAX
- 40 Aurora
- 955 Maestro
