Maestro Eror Not start up.
My Maestro won’t start up is the older type the on/off button on the top.
I have this info on my Maestro.
Kod 0xc0000001
You need to use the recovery tools on your installations media.If you don’t have any
Installations media. Contact your system administration or pc manufaktur.
Yes I need som help If anyone knows how to do it.
73 de SB6A/ Pierre Gassander
This may not work but when I had a similar issue on my maestro A unit, like yours, I unplugged the power cord for 2 minutes and then plugged it in and the maestro fired up. Also the forum has recently said that the latest software may have some bugs in it. On my 6400m I had similar msgs last Sunday so I rolled the software back and it works. I hope these can help you resolve your issues. If not you may need a service ticket so you can talk to the Team
Al
w1nga
Our support team is managing this.
Hello
I have a problem with the new software 3.5.8 I download it to my Flex 6500 without problems, It works perfectly fine.But then when I go down to my Maestro, I can’t Connect to the network and the radio.I know that the nerwork is ok.Can’t bring up any new softwork in the Maestro menu either.Have downgraded the radio to 3.4.24 and then everything works properly. Does anyone have an idea what it could be .
73 de SB6A/Pierre
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
