How to configure 13 cm Transverter interface ?
Dear OMs, I want to use Flex 6500 to drive a 13 cm Transverter.
My 13cm Transverter needs 2m signals for drive. Therefore I use Flex 6500 together with my 2m transverter.
My question: Is there a way to configure Radio Setup from a Flex 6500 / XVTR that it recognizes 144.000 MHz IF Frequency to show 2320.000 MHz at the display ?
My setup function marks this configuration as "invalid".
73, Wolf - DF7KB
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsYes. This is a good question.
It is actually pretty simple. Use an IF of 2320.000 - 28.000 = 2292.000.
This should work. The radio really doesn't need to know about the 2M transverter. It only needs to know the IF for the FlexRadio (28Mhz) and what the Display frequency is (2320Mhz)
Set the correct drive level on this window for the 2M Transverter
It should look like this
Let me know how you make out.
