Maestro vs 6x00M display resolution
The 6x00M models have an 8" display supporting a 1920x1200 resolution; however the Maestro has an 8" display with a 1280x800 resolution.
I must admit I'm a little baffled as to why the Maestro wouldn't have had it's screen updated given that the 6x00M basically contains a Maestro?
I'm guessing here: the Maestro supports a teeny-tiny screen where high resolution isn't important. The M models support large screens (mine is 32 inches) where better resolution is critical.
Early Maestros ( sometimes called version A) had the lower screen resolution screen. Version B Maestros have the same resolution as in the native 6x00M radio display. The screen and the location of power button are the major A vs B differences.
AL, K0VM
Thank you Al. I was looking at the data on the flex website and they have the lower resolution listed. That is what caused my confusion
Interesting. The picture on the Flex site is a B model, but the co-located specification says 1280 x 800. Moreover, a posting by Tim says the display module was changed, but had the same specifications.
Hence the confusion Hi Hi
The hardware display resolution changed between Maestro A and B but the Software resolution stayed the same. 6x00M's to date use the same display as MaestroB. They could be different in the future.
AL, K0VM
- 310 Community Topics
- 565 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 384 SmartSDR for Mac
- 253 SmartSDR for iOS
- 241 SmartSDR CAT
- 176 DAX
- 364 SmartSDR API
- 8.9K Radios and Accessories
- 106 FLEX-8000 Signature Series
- 886 Maestro
- 49 FlexControl
- 840 Genius Products
- 432 Power Genius XL Amplifier
- 296 Tuner Genius XL
- 112 Antenna Genius
- 263 Shack Infrastructure
- 184 Networking
- 427 Remote Operation (SmartLink)
- 132 Contesting
- 685 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 914 Third-Party Software
