Maestro vs 6x00M display resolution
The 6x00M models have an 8" display supporting a 1920x1200 resolution; however the Maestro has an 8" display with a 1280x800 resolution.
I must admit I'm a little baffled as to why the Maestro wouldn't have had it's screen updated given that the 6x00M basically contains a Maestro?
I'm guessing here: the Maestro supports a teeny-tiny screen where high resolution isn't important. The M models support large screens (mine is 32 inches) where better resolution is critical.
Early Maestros ( sometimes called version A) had the lower screen resolution screen. Version B Maestros have the same resolution as in the native 6x00M radio display. The screen and the location of power button are the major A vs B differences.
AL, K0VM
Thank you Al. I was looking at the data on the flex website and they have the lower resolution listed. That is what caused my confusion
Interesting. The picture on the Flex site is a B model, but the co-located specification says 1280 x 800. Moreover, a posting by Tim says the display module was changed, but had the same specifications.
Hence the confusion Hi Hi
The hardware display resolution changed between Maestro A and B but the Software resolution stayed the same. 6x00M's to date use the same display as MaestroB. They could be different in the future.
AL, K0VM
- 654 The Flea Market
- 385 SmartSDR API
- 52 Aurora
- 968 Maestro
- 940 Genius Products
