Stream Deck With FRSTAC and SDR 3.4.24
Good Afternoon
I watched the Video
Stream Deck setup with FRStack3 and SmartSDR on Windows 10/11
and followed the directions, Clicked and ran the Rest Call and loaded the stream deck plug in. and rest call 1.2. I then added http://127.0.0.1:13522/api/Radio/Slice[?parm=DOWN] to URL 1 for next clent and http://10.0.0.7:5025 to URL 2, the same is under both Buttons Next Client xx and next slice XX.
I have the proper display on the Stream Deck device however it will not communicate or work the radio/sdr? Is there a setting in FRSTACK or Smart SDR I need to change? or did I miss something on the Stream Deck FRStack3 set up?
thank you,
Chuck Bigbie N5ANY
Possibly a Firewall issue: temporarily turn it off and see if any difference.
or
Possibly port 13522 is blocked: temporarily change to 13523 in Stream Deck AND in FRStack
(C:\Program Files (x86)\FRStack3\FRStack.exe.config) and the line to edit is <add key="RestPort" value="13522" />
again, see if any difference.
This is for Stream Deck and FRStack on same PC
Set URL 1 to http://127.0.0.1/api
and then set Global URL to URL1.
The Get URL is /ActiveSlice/mode
The Click Param is param=DIGL
The Preview command is http://127.0.0.1/api/ActiveSlice/mode [?param=DIGL]
Your mistake was trying to put the whole command into URL1. Only http://127.0.0.1/api goes in the URL1,2,3 or 4 field where 127.0.0.1 is the IP of the PC running FRStack.
The Get URL gets the status of the command.
The click param field is the param= which is the command sent when you push the Stream Deck button (without the ?)
73 Dave wo2x
Thank you will try tonight at home.
Chuck
Chuck
Hi Dave
I made the changes, however I may have not done them correctly:
I put the IP address of the PC running frstack on the network 192.168.10.70 in URL 1 and the IP address of the radio 192.168.10.65:5025 in URL2 and still no connection or control of the radio? Did I miss something?
Chuck
I also tried it this way:
You do not need the URL2. You only need to communicate to FRStack. Also the Prefix and Suffix boxes should be empty.
If StreamDeck is plugged into same PC as is running FRStack and StreamDeck software is running in background, then the IP address for URL1 should be http://127.0.0.1:13522/api
I forgot to include the port number 13522 . If you are running Stream Deck on a PC different than the PC running FRStack then it would be the IP of the PC running FRStack instead of the 127.0.0.1
Make sure in FRStack that it is connected to your radio.
If you are running FRStack on a Raspberry Pi (part of Node Red install then URL1 should be the IP address of the Pi and :5025 (no /api at end) . Example - http://192.168.1.55:5025
73 Dave wo2x
Thank you so much for all the help it is now communicating, I will try it out!
73"s Chuck N5ANY
Good Morning,
I made the changes to the stream deck and immediatly I have an error on Power Genious Utility? I made no changes to that at all. I did however reinstall the software after I received this error mesage and I cannot get it to connect. None of the IP addresses changed on my system, as far as I can tell. I have them set as static and the Power genius displays the same IP as the Utility??
Is this the correct display on the Stream Deck?
Thank you for all the help.
Chuck N5ANY
Try changing PG XL to DHCP reservation instead of static IP. Unplug amp, wait 30 seconds and then plug back into power.
How do you change the PG XL to DHCP if you can't get the utility to connect to it?
and there is no network configurtion tab now.
You’ll need to reset the amp to factory defaults.
Open a Help Desk ticket for correct sequence as I am not near my PC now nor will I be for a few days.
Dave De **** wo2x
Flex Radio Presale Support
Reset complete all good NOW!!!!
Thank You So Much!
Chuck N5ANY
Next project node red!
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
