SSDR multiple slice antenna selection 6600M?
I seem to have messed up something AGAIN. I used to be able to have 4 slices open with 3 (XVTRA, Antenna 1/2) separate antennas.
HF (10-75M) 2 slices sharing antenna 1 (RX) or one on RX B (RX only Loop)
6M on antenna 2
Transverter on XVTRA (2M)
Now ALLL of the HF/6 are tied to which ever RX antenna is selected in one slice. In other words if I select antenna 2 in the 6M slice (the correct antennas) the HF RX antenna switched to ANT 2 and if I switch to antenna 1 (RX) the 6M does too. This is running Smart Control, which I prefer, rather then multiflex
Thanks es 73
Sandor KG4FET
Hi Sandor
Which model of radio are you using?
I thought I included that..6600M
You didn't mess anything up, only two different RX antenna selections are possible with a 6600/6600m/6700, not three . All other models allow only one RX antenna selection at a time.
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
