No audio when recalling a memory
My bet is that the Squelch is Enabled for the memory channel, and yes, it does work for modes other than FM.
Is that it?
Does the volume control bring the volume up when that happens? It's possible that when you save to memory and if the volume is set low when you save to memory you are getting the volume setting at the time you saved to memory. James
No thanks. The volume is up when its saved and up when recalled....0
Can you post a screenshot of before (audio working) and after (audio not working ) you select the memory?
It might also help to see what your Memory Channels screen looks like.
@kA9EES
Ed - that is exactly what I am experiencing - I get sound for a split second when using a memory. This happens both with the Mac and Windows version of smartSDR. The developer of the Mac version thought that it is a bug in the firmware of the radio. How can I use the memories - is there a work around?0 -
All I have done is try to be aware of it. I should report it as a bug. @Mike-VA3MW Can you help us with this? Has anyone reported it as a bug?
@VA3MW - You nailed it! Thanks so much - I did not notice the squelch option. Much appreciated.1
This is a 'feature' that engineering slipped past us and this happens when some of the commercial code is brought into the amateur version of SmartSDR.
The good news is that you can get squelch on SSB if you recall it from a memory and it is set to where you last had it in FM mode.
The 'bad' news is that fully adjustable, but I am sure that will get fixed in time.
I get the same behavior. I am not using memories. I don't know how to activate the squelch. I am observing the AGCT going to zero.
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
