Antenna Genius- NO bypass when power off
Is there a magic configuration that allows the antenna to be connected to the receiver when I power down the tuner? Hence, when the tuner is tuned off, the receiver is disconnect from the antenna. Not great for remote operation....
Also where is the tuner genius software applet for the main SDR program?
    When you power off the AG, all antennas are grounded for safety reasons. This is the way that 4O3A designed it such that when you power down your remote, all antennas are grounded.
    The AG software is not integrated into SmartSDR. However, you do not need the Windows Application running in order to have it track your antennas. It will automatically do that.
