Antenna Genius 8x2 Enclosure
N3BUD
Member ✭
I recently purchased an Antenna Genius 8x2 and would like to mount it outside on the side of my house rather then run the coaxes into the house. Any one mount theirs like this and have a recommendation for a weatherproof enclosure.
The key part of mounting outside is not necessarily 'waterproof'.
You want to make it hard for water to get in and easy for water to get out.
Since water seems to fall mostly in a downward direction 99.9% of the time, if you shield it from rainfall, you should be just fine.
As an example, we had a switch partway up a tower in a plastic box with no bottom. It was there for over 10 years with no issues experienced.
This is my setup
- 383 Community Topics
- 639 The Flea Market
- 146 SmartSDR+
- 434 SmartSDR for Mac
- 273 SmartSDR for iOS
- 262 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
