cw key often does not xmit
I read all the messages about cw and I'm not sure my problem is the same as described in those msgs. I see lots of talk about cw dropout, is that what I have here.
Have a 6400M running v3.4.24. My problem is that often when I push any cw key the xmit light comes on briefly, maybe a half second, then the light goes out and the radio goes back to rcv. But the radio does not xmit, even for that brief time when the xmit light is shining bright red. Sometimes it even does that twice before it resumes normal xmiting. It does it with the first character of a letter or even in the middle of a letter.
I have adjusted the tx delay up and down. I have changed the Delay up and down. No difference. It does it whether using the face of the 6400M or using SSDR Multiflex.
I turned off the radio and when I turned it back on the problem was still there. I did a complete reset of the radio, reloaded the profiles and the problem persisted. It does it using a paddle inserted into the key jack and also using multiple different keys and key types hooked up to the acc plug.
It seems that this is not an external problem but rather is caused by an internal malfunction. Is there a work around that I have not yet tried? CW is more than half my operating so it is important to me.
Fred, K0FG
Try using dummy load? Any reading at all on power out or swr indicators? Check your key connection. Etc.
73 es GL
Martin AA6E
With the straight key:
--"Iambic" control disabled?
--"Dot/Dash Swap enabled?
--Straight key wired per manual?
Have not used dummy load but doubt that it would show anything considering that the xmit light is only on for maybe half a second. The power out indicator on the screen shows nothing. Makes no difference if I run 1 watt or 100 watts.
The straight key, cootie and bug are connected in parallel into the acc port. They all exhibit the same problem. When they work, 99% of the time, they work just fine. It's just this once in a while they don't work. Enough to send your cw into a spin when you don't get one character and then get the next character and you have to go back and resend the letter. When the xmit light comes on but there is no sidetone it's obvious you are not putting out any power. Pretty sure it is not the keys.
But keep giving me ideas, maybe we will find one that works.
Fred, K0FG
Are you tuned to a valid ham frequency?
If I were not tuned to a valid ham frequency why would it xmit 99% of the time and not the other 1%?
Fred, K0FG
Please open a support ticket.
Thank you I will open a support ticket.
Fred, K0FG
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 280 FLEX-8000 Signature Series
- 958 Maestro
- 935 Genius Products
- 343 Tuner Genius XL
- 305 Shack Infrastructure
- 214 Networking
- 142 Amateur Radio Interests
