Heil Headset Pro 7 and Heil HS-2 Hand PTT
KG5PTE
Hello will the Heil headset Pro 7 work with the Flex 6400 ? Is there anything in the manual on this ? How about the Heil HS-2 Hand PTT too ?
Thank you.
Hi KG5PTE... best bet would be contact Heil directly and ask them. Typically, it's a case of getting the right plugs on the ends to fit into the 6400 mic jack and then determining whether the mic element requires bias and/or the 20db boost.
- 388 Community Topics
- 156 SmartSDR+
- 53 Aurora
- 970 Maestro
- 944 Genius Products
