Heil Headset Pro 7 and Heil HS-2 Hand PTT
Hello will the Heil headset Pro 7 work with the Flex 6400 ? Is there anything in the manual on this ? How about the Heil HS-2 Hand PTT too ?
Thank you.
  • VE7ATJ_Don
    VE7ATJ_Don Member ✭✭✭✭
    Answer ✓
    Hi KG5PTE... best bet would be contact Heil directly and ask them. Typically, it's a case of getting the right plugs on the ends to fit into the 6400 mic jack and then determining whether the mic element requires bias and/or the 20db boost.
