Static IP Address
Thank you
Best Answers
The preferred way to assign a static address to your Flex (or any other device on your network for that matter) is exactly as you mention - use the router to bind, or assign, an IP address based on the device MAC (hardware) address. Just be sure to specify an IP address that is not in the dynamically assigned range. I always start dynamic assignment high, maybe 150 or so on a /24 net (which almost everyone uses).
You can use a static IP address, but generally it is better to use an IP Reservation in your router to keep the same address. Mine did that automatically. I think I selected uPNP, but it has been 3 years and I haven't had to change anything - it just always works.
Check out the user guide, it will get you right where you need to be.
Yes I been looking for a link to the user guide (PDF)
Thank you.0 -
Thank you sir.
James (KG5PTE)0
- 369 Community Topics
- 628 The Flea Market
- 85 SmartSDR+
- 422 SmartSDR for Mac
- 270 SmartSDR for iOS
- 35 Aurora
- 244 FLEX-8000 Signature Series
- 937 Maestro
- 54 FlexControl
- 916 Genius Products
- 333 Tuner Genius XL
- 451 Remote Operation (SmartLink)
- 780 Peripherals & Station Integration
- 996 Third-Party Software
