Error (Unhandled Error - Non-UI Thread)
I made two new profiles today on my 6600 and then deleted the single orriginal one I had. I renamed it to match the new one. I then got an error and the SmartSDR closed. It was able to be re-started but when changed the profile it crashed again with an additional error. The smaller of the two is the second one, the same larger also popped up as well the second time. When it starts up it starts with the profile that was switched to and causes the crash. It occurs back and forth, does not matter which one it starts with. I will be deleting both and restating and making both from scratch to see if occurs again. attached are snips of the error screens.
So I deleted both of the two profiles I had. Rebuilt from scratch. Same issues. 4 slices on a 6600 running v3.4.24
Hi Glenn, I would submit a help desk ticket.
Hello, have same kind of problems here with 6400M, can not run 2 slices. Will submit a ticket as well.0
- 390 Community Topics
- 662 The Flea Market
- 440 SmartSDR for Mac
- 55 Aurora
- 971 Maestro
- 946 Genius Products
- 308 Shack Infrastructure
- 216 Networking
