PGXL Port B Issue
I've owned the PGXL for going on three years and have only now had a need to hook up a second transceiver. The old IC-7851 is on Port A and the new IC-7300 is on Port B. Port A still works as it should. Port B seems to work well in PGXL standby mode -- RX and TX all OK and SWR is good. Then I go to PGXL operate mode -- receiver still receives but the exciter shows infinite SWR and no RF out when attempting to transmit. Both exciters key the PTT line in the PGXL and CI-V is working OK for both exciters.
So I decide to put the old IC-7851 on Port B (with corresponding cabling and CI-V changes) to see what happens. Same problem. Port B gives an infinite SWR reading on the exciter.
I've re-read the manual multiple times looking for an answer. Have I missed something?
Open a Help desk ticket.
Sounds like an issue with SO2R switching inside the amp.
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
