Possible Utility Bug
Found that i cannot connect more than 2 instances if the TGXL utility to the tuner. Had it running on 2 pc’s and tried to bring it up on ipad through SDR iOS by Marcus and it would not connect unless I disconnected one of the TGXL Utilities on the pc… Thoughts
It is not a bug. By design, only two simultaneous connections can be made at a time.
I can make 4 or 5 with the PGXL so why limit tuner to 2
For me, the limit on the PGXL is 3 simultaneous connections.
You may have to email 4O3A and ask them. They do not monitor the community.
If you have the SO2 R tuner and Antenna Genius, it also has connections to the AG and radio. That would be four total.
From 403A
Dear Steven,
As far as I know our Windows apps support multiple connections as you were able to see but the iOS might not.
Software wise it shouldn't be a problem but only Marcus can answer that question.
I would suggest sending him this question and a request to update the app in case he limited it to two connections?
Kind regards,
Dragisa 4O9ITT
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
