How long does 3.4.23 update take on 6600?
Paul Carff
Paul Carff Member ✭✭
Been stuck on this screen for a long time - just finished breakfast and it is still there.
  • Paul Carff
    Still stuck here. How do I properly cycle the 6600?
  • VE7ATJ_Don
    VE7ATJ_Don Member ✭✭✭✭
    Hi Paul... to cycle the radio, just press the power button to shut things down. Then, wait about 30 secs, then you can power it back on. That should get things going again on the update sequence.
    If that doesn't work, then you should try a full reset of the radio. From the manual...
    "With the radio powered off, press and hold down the power button until the Power LED blinks white, then release the power button. Allow the radio to continue booting normally."
  • Paul Carff
    I have tried both and neither worked. I am going to try an older version and see what happens.
  • Paul Carff
    So my radio says is is already on 3.4.23
  • Paul Carff
    SmartSDR shows
  • Paul Carff
    I have noticed the radio has a yellow solid led. SOLID YELLOW = GPS in holdover (lost satellites)  Woudl that prevent this?
  • Paul Carff
    OK it is now showing SOLID BLUE = GPS locked
  • Paul Carff
    Still no joy with SmartSDR
  • Trucker
    Trucker Member ✭✭✭✭
    Did you download the latest version of SmartSDR from Flex Radio? If you are trying to use an older version it will show the screen that you posted. If you are using the latest version on your pc, then you may have another issue.
  • Paul Carff
    Yes I am using the current version from SmartSDR - reinstalled it today.
  • Paul Carff
    Starting from scratch-
    Cold Boot radio. and Fresh install of SmartSDR on my laptop
    start update -
    Radio has purple light and then flashing green and then solid green.
    SmartSDR has the yellow progress bar reach 100%
    And is stuck.
  • Trucker
    Trucker Member ✭✭✭✭
    Might be Help Desk ticket time.
    Paul is working with our support team.
