Network Status window only shows close button
minorsecond
Member, Unconfirmed ✭✭
I've searched the Windows forums for this first, but didn't find an answer. When I click the network indicator in SmartSDR to see network stats, all I see is the close (X) button that appears on the upper right of windows. The link below is a screenshot.
https://imgur.com/a/Iy4YIxF
Is there a way to fix this?
I opened a support ticket for this.
I have the same issue here on Flex 6400, v3.5.8 on Windows 11. Is this a known problem or should I open a ticket?
Thanks, 73
Alessandro I2SVA
Hi Alessandro, you should open a ticket.
I'm getting this too on 3.7.4 and Windows 10. Anyone get the solution from Flex?
John N1JM
2 things it could be. One, is off the screen some place.
The other is that it was minimized somehow. It really isn't a SmartSDR bug, but more a Windows issue. Sadly, the only thing I can think of it to fix it is to delete all the settings for SmartSDR in %appdata%, but then you are at risk of losing other settings.
Of course it works ok on my Windows 11 PC 😊. Maybe I'll try uninstalling and reinstalling 3.7.4 on my Win10 PC.
- 650 The Flea Market
- 154 SmartSDR+
- 50 Aurora
- 964 Maestro
- 938 Genius Products
