2.9.1 CW Still Broken
Geoff AB6BT
Geoff AB6BT Member ✭✭✭
Just upgraded to 2.9.1 on a 6400 and the CW mode is still broken. I just called a couple DX stations on 15 Meters and couldn't send a coherent call. Luckily after a few attempts the DX figured it out.
The only way I can fix this is the reboot the radio.
This is really frustrating!!!
  • Dan Trainor
    Dan Trainor Member ✭✭✭
    They apparently no longer fix CW bugs anymore.
  • Geoff AB6BT
    And no comment from anyone at Flex...
  • Mike Proske
    Mike Proske Member ✭✭
    Same issue here 6400m
  • Geoff AB6BT
    Yeah, I believe it is a well known, long-standing, problem affecting many CW operators.
    I don't understand why there has been no fix applied lo these many years.
    Perhaps there is no remedy and we'll all have to resort to external keyers...
  • Mike Proske
    I believe that folks have still had issues with external keyers otherwise I would have gone that route some time ago
  • Geoff AB6BT
    You may be correct, but I haven't noticed a problem with a straight key so my assumption is that an external keyer would work.
    I have not tried one yet.
  • Geoff AB6BT
    What percentage of CW operators experience this?
    If the percentage is low then I might be able to understand Flex's lack of action to resolve the problem.
    On the other hand, If the majority see the same problem then I see no reason why this should not be addressed and fixed.
    Can anyone answer my question?
  • phillijs
    phillijs Member
    I have the same issue with CW, good to know that you can re-boot and correct the problem. Hopefully, the issue will be identified and corrected.
    John
    KL7RI
