Flex-6700 Display Problem
When I turned on my Flex-6700 running SmartSDR 2.9.1 this morning, I experienced a display problem. The display had a green cast with diagonal lines as indicated in the attached file. I have tried the usual stuff like power on and off, computer restart, and a reset of the 6700 with no luck.
I am wondering if this is a hardware problem that has developed or if there is some other way to return the display to its normal state?
Thanks in advance!
Ed, K0KC
By the way, this is not a monitor problem. The screen looks the same on another network computer.
Ed, K0KC
It looks as though you have a TNF set and you have zoomed in so you are seeing the width of the notch filter.
I can't read the frequency limits of you display.
Try zooming out.
Either that or he as a REEEEEAAAAALLLLLYYYY wide TNF set :-) !
Geoff and Don,
I feel really **** this afternoon...you guys were right, I turned off a TNF and everything was back to normal.
Thanks!!!!
Ed, K0KC
- 379 Community Topics
- 636 The Flea Market
- 140 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 271 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
