关机后,开机就出现 ERROR PSL3V3-0.02 这样的显示,一直卡在这里
BG7BDB
Member ✭
What equipment are you running? Where does the error show up (SmartSDR? Front panel?)?
Translation -- "After shutting down, the display such as ERROR PSL3V3-0.02 appears at boot and has been stuck here"
I would say you need to send it in to get the 3.3v Regulator replaced. As that's a classic sign of unstable voltages on the 3.3v bus.
I had to send my 6700 back for the 1.0v Regulator and the 3.3v Regulator with the same errors.
您好,您可能想尝试清洁收音机背面的直流电压连接器,看看是否有帮助。
接下来,打开收音机,对收音机中的保险丝进行同样的操作。 通常,这可以解决问题。
Nín hǎo, nín kěnéng xiǎng chángshì qīngjié shōuyīnjī bèimiàn de zhíliú diànyā liánjiē qì, kàn kàn shìfǒu yǒu bāngzhù.
Jiē xiàlái, dǎkāi shōuyīnjī, duì shōuyīnjī zhōng de bǎoxiǎnsī jìnxíng tóngyàng de cāozuò. Tōngcháng, zhè kěyǐ jiějué wèntí.
- 389 Community Topics
- 53 Aurora
- 970 Maestro
- 944 Genius Products
- 307 Shack Infrastructure
