Sound
Hio all
New issue here...
I have the sound muted on both the top right menu of SSDR (version 2.7.6 , it was just impossible to install version 2.9, no idea why !), as well as in the menu just below the frequency indication. BUT I still hear the sound.
Whether I have PC Audio selected or not makes no difference. I still hear the sound.
What am I missing (Windows 10) ? I want to mute it (basically when I work FT8)
Thanks + 73
Paul F6EXV
Hi Paul... can you give us a bit more detail as to how you have connected up your radio soundwise?
What radio are you using? Are you just using the audio from the PC? Is there anything plugged into the headphone jack on the radio itself?
I'm not sure what you mean by "I have the sound muted...top right menu... menu just below the frequency indication."
On SmartSDR (for Windows PC), here's what my flag looks like:
The 'mute' button is one the left (the speaker) and you need to right click it to mute it off.
What are you seeing? That would help us.
Don
1/ Yes, I have speakers connected to the Flex 6500 (sorry I forgot to mention the rig) , in the back.
2/ Yes, the mute button is on, both in the flag as you show it, and next to the PC Audio button at top right of SSDR screen.
Paul F6EXV
Now, something new... Will it ever work and stay stable ??
I hear the 6500 sound on both the speakers connected to the Flex, and on the speakers connected to the PC...
When using the Flex, I only want the sound out of the Flex speakers. How to achieve that ?
Also, why is it impossible to install version 2.9.1 ? And should I install it ?
Thanks + 73
Paul F6EXV
In SmartSDR, unselect PC Audio in upper right to mute PC speakers.
What fails during upgrade? You may want to open a Help Desk ticket. Sounds like something in the PC operating system is blocking the upgrade.
Hi Dave
PC Audio is unselected (not blue).
Update to 2.9.1 gets stuck, no error message, but no update !
Paul F6EXV
Hi Paul...
I'm assuming you've got your speakers connected to the Powered Speaker/Line Out on the back of the 6500?
And how have you got the PC connected to the radio?
The 'mute' button in the top right of SmartSDR only mutes the PC Audio stream. The one in the flag (as I presented) mutes audio from the slide receiver.
BTW, I'm running 2.9.1 on my 6500, so I know it will work. And mine is rock-stable -- I pretty much leave it on 24x7.
As Dave said, I would take note of any error conditions, lights flashing on the front panel, etc. and contact the Help Desk.
Slight correction... The mute button in the upper right hand corner mutes all slices whether audio is coming from the radio speakers or PC Audio. The mute buttons on the individual slices mute each slice independently.
Hi Don
Yes, speakers connected on the back of the 6500. There is only one way to connect the PC to the radio, USB cable. Any way, after "playing" around with the 25 million sound cards shown by Win10, I think I solved the issue... untill next time.
Ecevrytime (or close) I close the Flex to go to my 7300 for 6m FT8, the computer looses track of the sound card to use. This is extremely anbnoying, but I think it is a Windows issue.
I will try again for version 2.9.1. Wghen I aml ready to go to bed, so as to leave time for my PC to work all night !
Paul F6EXV
**** again !
JTDX (or any other FT8 program) again looses its configuration. There is reading on SSDR waterfall, but no decoding on JTDX...
JTDX has the correct sound setup, but no decode. I am about to sell my 6500 !
Help please (tomorrow, I am off to bed ...)
Paul F6EXV
Hmmmm, Paul... I'm concerned about your statement "There is only one way to connect the PC to the radio, USB cable." That's not correct. I'm hoping you mean you have the radio connected either directly to the PC via CAT-6 ethernet cable, or the radio is connected to a router/switch (again via CAT-6) and the PC is also connected to the router/switch via CAT-6, or the PC is connected via WI-Fi.
The USB ports on the back of the 6500 are not for interconnection of the radio to the PC. From the SmartSDR manual (page 118) "The USB Cables feature provides a means to control external devices such as amplifiers, antenna controllers, and tuners via USB to Serial data cables..." "This feature is limited to FTDI USB cables which contain embedded circuitry..."
I'm assuming your "... playing with Win 10 sound cards..." is to do with getting the speakers attached to your PC to work???
Again, a description of how you have your PC and radio attached together would help. (All the connections :-) )
Sorry, can't help you with the JTDX stuff, but there are lots of people here on the community that do that. I would suggest posting a new topic with that as the header. I do remember you must select DIGU as the mode in order to get sufficent bandwidth for decoding....
Hi Don
Yes, I guess my nervousness made me write this statement wrong... The Flex is connected via a router. The Flex does work fine, the sound card does work, and I do get the sound to the proper speakers.
I will follow your advice and sart a new post for my FT8 issue.
Thanks + 73
Paul F6EXV
- 363 Community Topics
- 624 The Flea Market
- 8.1K Software
- 69 SmartSDR+
- 420 SmartSDR for Mac
- 270 SmartSDR for iOS
- 253 SmartSDR CAT
- 188 DAX
- 379 SmartSDR API
- 31 Aurora
- 233 FLEX-8000 Signature Series
- 933 Maestro
- 909 Genius Products
- 329 Tuner Genius XL
- 120 Antenna Genius
- 291 Shack Infrastructure
- 204 Networking
- 448 Remote Operation (SmartLink)
- 771 Peripherals & Station Integration
- 989 Third-Party Software
