FlexButtons V1.5 Released
I've released FlexButtons V1.5 at http://www.kregli.com. It exposes a number of new functions including some control of a TGXL and it allows switching between multiple layouts. A couple of really different layouts are shown below.
ONE CLICK!
You can combine two or more functions on one button, such as: on slice A go to 21.035Mhz, CW with a 200Hz filter, the panadapter zoomed to 10 kHz, set PoWeR to 25W, BYPASS the ATU, set the TGXL to AUTOTUNE and the PGXL to OPERATE.
hi Keith,
One comment. The TG XL does not have an auto tune mode. It is either bypassed or in circuit. The tuner requires the op to train the tuner on each band & antenna. Then when in circuit (not in bypass) as you change frequency, the tuner uses the closest tuning solution.
It's called Autotune in tglib.dll, so I called it that. It just invokes the tuning function. Do you know a better name for it?
In Node are d I just called the button TUNE. When pressed it initiates a tune cycle and will store results in one of the 20 memories for the band.
That was my initial thought - should have stuck with it :) I'll change it in the next version.
- 681 The Flea Market
- 393 SmartSDR API
- 98 Aurora
- 991 Maestro
- 965 Genius Products
- 353 Tuner Genius XL
- 319 Shack Infrastructure
- 224 Networking
