No changes to computer or LAN 6300
I have 6300 and it's been perfect so I do not think it's the radio. Everything has been working as it should. I have several computers on my home LAN. the one in the room with the 6300 works as it should plugged in to the router in that room. On the other side of that wall is my home office where I have another machine I use to listen and monitor my 6300 so I can bag the occasional FT8 contact while working, its on a WIN 11 desktop. Both computers are on the same LAN and off the same master Verizon Modem/router. The strange part is everything has been peachy until a few days ago and now my office machine will only connect via Smartlink, it's not seeing the 6300 on the network directly. Thus, Slicemaster doesn't work. It shows no connections. I have done resets etc. and am stumped.
If you office computer only works via SmartLink then something has changed and it is likely on a different subnet or, for some reason the firewall may have been turned on your office computer. Those are a few of the things I would look at.
Your office computer is not hearing the broadcast messages from the radio for some reason.
What are the IP addresses of the Radio and the 2 computers? That may help us to diagnose further.
Thanks, I will look at the firewall first then look at the IP addresses.
Regards! Funny I never noticed the 5 years going by so fast!
Pat
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
