SLICE MASTER 6000 losing connection to slice A & B
W5IO
Recently upgraded to Smart SDR 2.9.1. Now when trying to use Slice Master for CW the connection to either slice keeps dropping. Rebooting did not help.
Any solutions out there?
After you upgraded to 2.9.1, you might want to reset the radio database after you export your profiles.
See how that works.
Hi Mike
I'm not sure I follow this logic. I exported my profiles pre-upgrade then imported them back in. Profiles manager lets me reset transmit and microphone but not global. Not sure why I would need to reset transmit or microphone for Slice Master? I did try, with no change.0 -
The reset I was referencing was a radio reset.
If the connection keeps dropping, there is some sort of lost communications issue between the radio and the user client that needs further investigation to isolate. You may wish to open a support ticket.
- 339 Community Topics
- 607 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 172 SmartSDR for Maestro and M models
- 403 SmartSDR for Mac
- 265 SmartSDR for iOS
- 248 SmartSDR CAT
- 186 DAX
- 372 SmartSDR API
- 9.2K Radios and Accessories
- 19 Aurora
- 194 FLEX-8000 Signature Series
- 916 Maestro
- 887 Genius Products
- 321 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 744 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 961 Third-Party Software
