6700 v3.4.21 RF Gain
Hi.
Just updated to version 3.4.21 all looks OK apart from ANT RF setting has to be on +20db when on a signal below S5, if I put it back to +10db or below as it was before the update its like there is a squelch on.
Read through what I could fine but nothing with the problem I have, knew I should have left well alone :-)
6700
Thanks in advance
John
    edited February 2023
    What is your AGC-T set to before and after you change the gain?
    I tried to recreate your problem, but I didn't see the same thing.
    Which band was this on and which antenna where you using?
  • GM7PBB
    GM7PBB Member ✭✭
    It doesn't matter where the AGC is set, tried all different ways and still nothing, if I delete the slice and make a new one it works fine for about 5 mins, then off again, very strange. this is on 60m or any band.
  • GM7PBB
    GM7PBB Member ✭✭
    I have just changed to FM and took the squelch off then back to SSB and it worked for a while, going back to FM noticed that the squelch is high lighted again even when I took it off.
    Can you open a support ticket for this please so they can accurately track what you are seeing.
  • Kelsey Mikel
    Kelsey Mikel Member, Unconfirmed
    Mike I don't have a problem recreating Squelch for SSB on my 6700 running 3.4.21. Just wonder if Flex has this running on their commercial or gov software? I can be reached at k5pwr1967@gmail.com
  • Kelsey Mikel
    Steps:
    1 - open a memory channel you have saved ( doesn't matter what band but try 40Meters )
    2 - make sure Mode is set to USB and squelch is checked
    3 - click on this channel, radio will tune that to Freq and receiver will be muted if no one is talking
    4 - 40 and 80 LSB will be received on this channel arrangement but in the RX Window Pane it is set to USB
    5 - On upper bands USB is correct
    6 - to change squelch level ( or audio mute ) Open ANT settings select 10, 20, 30, 40 ( 30 or 40 open squelch.
    7 - don't move the frequency or the radio will reset to normal operations
    8 - Have fun and yes I know it will be fixed but its nice to have squelch without an App
  • Kelsey Mikel
    Sometime you can drag frequency and it doesn't reset SQ K5PWR Keley
