Microphone Profiles
I made the horrible mistake of resetting all my microphone profiles to reconfigure them all.
Now I have 10 DEFAULT profiles and you cannot delete them.
What a mess. This software is a mess.
Reboot fixes it.. but jeez what a hot mess 2.4 is.
WHATEVER you do, DO NOT stick your finger in the hole.... The warning signs that state, WARNING ROTATING KNIVES fell off sometime before 2.3...
Provocative to say the least. I've heard about woman like you. ;)
What version of SmartSDR are you at? You can delete Default Mic Profiles, but if you do reset the radio, they will come back, which is by design.
If you have a 6400M or 6600M, Sec 18.4 of the user guide addresses both saving and deleting profiles.
Default profiles may be modified or deleted using the Profiles control panel.
Mike,
v3.4.21.14056
Go to Profile Manager in SmartSDR.
Create 3 new mic profiles to discard later.
Highlight one and then click Reset. Confirm.
Highlight a second one, then you'll see the first one changed name to Default. Click reset on the second one. Confirm.
Highlight the third one, and you'll see the second one now changes to the name Default. Click reset on the third and confirm.
Then highlight any other mic profile. You should now have 4 profiles named Default. None of which you can delete.
Now, If you reboot the radio and then go back to Profile Manager and look at microphone profiles, the 3 mic profiles you reset will now have their original names back and will not have been reset and you can now delete them.
This is so left-footed I have no words. Do you guys beta test anything at all?
And AM mode is seriously broken in 3.4.21. I cannot get 100% modulation. Everyone keeps telling me to turn up my mic gain, but it's maxed out.
Hey Dennis, perhaps you could send the testers an a priori list of things to check.
Crystal balls are great for this...
That would probably really help them out.
Dennis,
Please open a support ticket.
I just deleted all the default profiles other than Default and Default FMH-3 and rebooted the radio and you can see here, they are all gone.
This is a problem just with your radio and the Support team will get it sorted out.
And, yes we do have beta test programs in place since you took the time to ask.
Mike, did you do what I said above. You'll see that your's probably does it too..
- 338 Community Topics
- 580 The Flea Market
- 7.7K Software
- 6.2K SmartSDR for Windows
- 387 SmartSDR for Mac
- 253 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 365 SmartSDR API
- 9K Radios and Accessories
- 891 Maestro
- 50 FlexControl
- 849 Genius Products
- 298 Tuner Genius XL
- 113 Antenna Genius
- 269 Shack Infrastructure
- 190 Networking
- 134 Contesting
- 702 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 924 Third-Party Software
