Level adjustment queston Radio Sport headset with Maestro
Have a Radio Sport headset with the M20 Mic. The Maestro is set up per the included instructions with Mic preamp +20db disabled. I am using and have enabled MIC2, instructions say to use mic profile M360/EM56/M20. My profile does not include M20 electret mic. jusst M360/EM56 which does not work Only "Default" with gain at 100% works. I am using SSDR 2.8.1. The concern I have is in order to get full drive of the carrier I have to set the mic level to 100%. This does not feel right to me I would expect @ 50%, any guidance?
Thanks in advance
Steve AG4SO
Hi Steve... no, that doesn't sound right.
Maybe try enabling the +20db and see what happens.
Also, there are youtubes available that will show you how to 'listen to yourself' (setting up two slices on top of each other with the transmitter set to output to the Transverter port) which will let you hear how you actdually sound on the air.
Hi Steve I ran my radiosport on the maestro as a m350 wide at a gain of 50 once I got the correct cable from flex. Take care and 73
They sold me the CS6-MAE cable I it on the MIC-2 connector which I have enabled. It will not work on M350 Wide. Is this the same cable as yours?
Steve AG4SO
Well I am still trying to verify with FLEX I have the right head set cable my support request has disappeared twice after hitting submit. This morning I had NO TX modulation with headset so I switched back to my Heil Pro it works. Several possibilities at this point. Cable, Mic, setting, etc. Will try to submit a cable again.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
