For remote site is there any need to have a power disconnect?
At the moment the Flex is always connected to DC power and the Raspberry Pi watches for a VPN connection and will turn on and off the Flex radio when a VPN connection is active.
I am considering adding a latching relay such that the Flex normally has DC power but in the event that "something goes wrong" I can have the Raspberry Pi disconnect power to the Flex and then restore power. I want to know if there is any need for this ability. I would use a latching relay so I was not wasting current through a relay coil all the time.
I did have one experience in which the Flex radio did not boot up. I investigated and found that the red light on the power switch was giving 3 blinks then a pause which I believe indicates boot failure. I have the Flex and Raspberry Pi on a VLAN and think the error may have been caused by some firewall changes that messed up my network. I resolved this by disconnecting DC power to the Flex momentarily.
I do not know if toggling the remote power connection on the back of the Flex will do everything that actually power cycling the radio will accomplish. Does anyone know if a remote site should have the ability to power cycle the Flex radio other than using the remote on connection?
I am really enjoying this radio. I am a long-time ham but this is my first experience with a waterfall display and also my first experience being able to operate from the comfort of my office while the radio is out in a somewhat cold shack. This is a great new experience.
Thanks, Dale, K7FW
Hi Dale
I have been running remotely since 2005. For my FLEX-6600, I use the remote RCA connector for powering it off.
When I really want to shut down things, I use another relay to turn off the Power Supply (70Amp Astron).
I use a combination of KMTronic web switches to manage this which work very well if you want to keep it simple.
There are many IoT remote switches that will work as well.
I think you will find that there are many answers to you question.
I spoke with someone at Flex and the answer is that for a remote site some way to power cycle the radio beyond just the auxiliary power jack is useful. There is always a chance that something could get messed up - this is a computer after all - and a power cycle would be desired. So for our remote site the radio will normally use the aux jack to switch power on and off but we will also have a large normally closed relay that we can open to remove power from the radio should we ever find that necessary to force a full reset.0
It is useful to have both the remote contact closure for the remote on/off and a complete power down. There are times where powering off the radio is needed. I recently upgraded the firmware on my 6600 remotely. a complete power cycle is necessary to reset .
There are many ways to achieve the remote power on with a relay contact closure. I have used the Microbit 1216H which has 5 relay contacts and each relay can be energized with port forwarding. Also I use the Denkovi 16 output relay module as a backup to my power on contact. I've also used other ethernet relays output cards to control the remote power on over the years. I have found that the WEMO Wifi outlets have not been reliable over the years and have switched to hardwired Ethernet relay cards with no failures this year at all.
I use the DLI Web Switch Pro at two remote sires. They have 8 individually switchable outlets. I use two DLI AC relays at each location. One for Radio Remote On and other for remote control of Aux PTT. Aux PTT needed for SmartLink registration changes.
A PC at each location set up in bios to turn on when AC is applied.
A Raspberry Pi at each location running Node Red server.
Both AC Relays, PC, Pi, rotor controller, SteppIR controller, 12 v supply, and fiber gateway/router are plugged into the Web Switch Pro. All equipment interfaced to Node Red which has a web based dashboard accessible from any web browser.
Over time, you learn what can go wrong at a remote site.
73 Dave wo2x
I have used WEMO Wi-Fi outlets on a nearly daily basis for 5+ years without issue. A very easy solution (with the inexpensive FLEX kit) for remoting the radio’s power switch and the power supply.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
