New To Flex and Trans power
This is the Flex 6400/ATU
Any help Ron W1VET
What power out is shown when using the tune button?
Ron - a few suggestions. (And sorry if some of this sounds obvious, as I don't know where you are with your learning curve.) First, make sure the "TX" on the Receiver Slice Flag that you have selected is Red (not grayed out). Also make sure the Receiver Slice is tuned inside the ham bands. Next connect the output of your 6400 to a dummy load, switch your ATU into the bypass mode (you should see "Success Byp"), then adjust your "Tune Pwr" slider mid-way, then click your Tune button for a short period. You should see a mid-scale RF indication on your RF Pwr meter, and SWR should be at or near zero. This will let you know if your transmitter section is working properly. Next test your ATU. Reactivate your ATU, and click on your TUNE button again and look for approximately the same power out with little or no SWR. Next adjust your RF Power Slider mid-way, select an active Microphone Profile and then its proper MIC connection (Mic, Line, etc). Key the PTT button on your MIC and speak into your Mic. If you are in the USB or LSB mode you should see RF Peaks indicated on your RF Pwr Meter as you speak.
KF4HR
Power out with rune button is 100
For ANT1 and ANT2 1 is Blue and 2 is red. I used a dummy load as well with same results, and I am a trouble shooter so ask away anything. I may have missed something, and this is the first Flex Radio.0
Hi Ron, the red antenna indicator is for transmit. Change the red one to Ant1 and I think you will be OK (assuming your antenna is on Ant1).
No bypass ATU and into a dummy load no power and high SWR0
Hi Ron, can you post a picture of your SmartSDR screen?
How can I get pic on here ?0
Windows has a built-in tool called "Snipping Tool".
Open it and click "New" in the upper left.
Draw a box around what you want to capture. The image will be on the clipboard.
Just paste the image in your reply here.
I just get file failed to upload.0
It looks as though you are not pasting the image from the clipboard.
Just right click in your reply and choose Paste or use ctrl-V.
You should see the image not a file name.
It uploads as a file as you see.0
As a test I'll try something.
Random snipped image pasted in my reply...
OK, well that worked. I'm not sure what else I can tell you. Perhaps someone else can chime in.
At the bottom left of the reply window there is an icon for uploading an image. Perhaps that will work.
IIRC, new members don’t get file upload capability right away.
if the tune power is showing 10, that is reasonable tune power out.
How are you generating the signal to check for power out?
Hi Ron, I think that you have DAX turned on. Turn it off and see if you get better results.
I agree The DAX button appears blue.
Ron - a few more things to try... Note your ATU "MEM" button is blue, click it and gray it out, then make sure your ATU indicates "Byp" then click on the TUNE button and retest your SWR into your RF Load. If your SWR drops to 1:1, make sure your Mode (on the Frequency Flag) is set to LSB or USB before you do your Mic test.
Also, if your Frequency Flag is indicating ANT 1 (blue, meaning receive) and ANT 1 (red, indicating transmit), make sure you have your RF output cable connected to the ANT1 port on the rear panel.
KF4HR
Nice try but no go. I think I am going to have to send it back for service. Great 2 contacts and love what this radio does, just wish I got more time with it.0
The notes you were given were all good. Especially check:
Often missed is Ant 1 is the inner of the PL259 connectors - See fine print on the back
Do a resistance check on your dummy load connecting cable - You didn't reply that you had a dummy load or it's type. The centre and shield should be 0 ohms end to end and not shorted together; I have seen many failed cables and connectors.
Measure the DC resistance of your dummy load for 50 ohms A) at the dummy load and B) with the cable connected.
Apologies if these statements are insulting, just trying to be all inclusive. The Flex SWR is calibrated 1:1 to 3:1 full scale. If you have a separate SWR bridge put that inline so you can independently see power and SWR.
If the cables and dummy load are good then cycle through the ATU settings (bypass and tuned). With a short pressing of the ATU button you should hear some clicks and the SWR reading adjust. When in Tuner bypass your external SWR should match the Flex SWR reading.
The most important readings are, on your inline swr/power meter, a power reading near your Tune % slider. Failing that repeat the test on Ant 2 to isolate that part of the flex power routing relays.
Hello Stan and everything you ask is fine and I know it is just incase I miss something so ask away. I have tested the cables and Dummy load, all are fine and next check was hooking my IC-7610 to the same coax and dummy load ( MFJ Dummyload ) and everything worked fine.
Tested ANT1 and then ANT2 I hear the relays on key up when using ANT2 but not ANT1. The power output is showing 10 to 15 watts on the radio screen but nothing into the Daiwa meter that is set at 20watts (2k meter). If I aply a little more power from the radio I then get a high SWR and the power out on the radio screen goes up but starts dropping slowly, and there is 0 output on the meter to the dummyload. This is the same on both ANT1 and ANT2 ports. The only thing I can think of that I have not tried is Factory reset but have not look on how to do that yet, what do you think?
Hey everyone thank you for all the help you are giving me.
Ron W1VET0 -
Time for a help desk ticket. They can access your rig to check on all settings , etc. very knowledgeable and helpful.
Ron - you can find the Flex 6400M Manual here: https://www.flexradio.com/documentation/flex-6400m-and-flex-6600m-user-guide-pdf/
Factory Reset procedures are in section 38, page 190.
KF4HR
Thanks for info and it didn't help so put in a ticket. It has me stumped.0
Let us know how this gets resolved.
- 247 Community Topics
- 488 The Flea Market
- 7.4K Software
- 330 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.5K Radios and Accessories
- 771 Maestro
- 42 FlexControl
- 727 Genius Products
- 252 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 371 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
