USB to Serial cable not detected by Flex 6500
I am trying to use a Ativa usb 2.0 to serial adapter cable to interface my Flex 6500 with my SPE Expert 1.3K-FA amplifier. The Flex does not detect the cable. I tried the cable on my Windows 11 pc and it is detected as a prolific usb to serial device.
Do I need a specific type of usb to serial adapter for use with the 6500.
Bob, KN4HH
Geoff is correct. If you download the "USB Cables Interface Guide for the FLEX-6000", it is clearly stated that only FTDI cables will work.
73, Craig KØCF
I believe it must be an FTDI device.
Thank you all for the information. I did download the Interface Guide. I will use an FTDI adapter.
73, Bob, KN4HH
Bob, if you need a cable I have several of the UT232R-200 FTDI USB-Serial cables that are still in the packaging. Just contact me and my email is good on QRZ.
John K3MA
I think the expert amp has FTDI built into its USB port. So, a simple USB cable will work.
Alan. WA9WUD
Thanks, Alan. I am using Dan Tassell’s cable set between the Flex and SPE. When I insert the prolific usb to serial cable into his serial input, it isn’t detected by the Flex. I will have a FTDI cable shortly.
Bob, KN4HH
Thanks for all of your comments. Replacing the prolific usb to serial cable with a FTDI cable solved the problem.
Bob, KN4HH
I supplied the FTDI cable to Bob KN4HH. I have several that I purchased from Mouser still in the original packaging authentic UT232R-200 FTDI USB-Serial cables. If you need one send me a email.
- 338 Community Topics
- 579 The Flea Market
- 7.7K Software
- 6.2K SmartSDR for Windows
- 386 SmartSDR for Mac
- 253 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 365 SmartSDR API
- 9K Radios and Accessories
- 126 FLEX-8000 Signature Series
- 891 Maestro
- 50 FlexControl
- 849 Genius Products
- 298 Tuner Genius XL
- 113 Antenna Genius
- 269 Shack Infrastructure
- 190 Networking
- 134 Contesting
- 701 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 924 Third-Party Software
