Programmatically engage SPLIT
SmartSDR 3.4.21
I'm using the .NET API. Given the "active" slice, I want to engage SPLIT. Here's what I'm doing at a high level:
Get the active slice
Call clone and get two slices (they're offset correctly for split by mode automagically - nice!)
Flag the new one as TX.
Everything behaves as SPLIT, except that the UI does not turn on SPLIT in the UI:
I even got the audio pan to put A on the left side and B on the right. Exactly what I want!
How do I get the SPLIT to light up in the UI?
Thanks, and 73!
Brian na8wrl
Hi Brian, I think that split is a function of SmartSDR, not the API. I went looking for it at one point, and realized that I can set all the split parameters (like you did) and get a perfectly functioning split, but since I set it myself, SSDR doesn't know about it. The API talks to the radio, not to other apps (like SSDR).
I should have known better, Len - this was the same issue with panadapter positioning as a slice moves.
I'm talking to the radio, not to SmartSDR
I should remember that by now!
Thanks!
-Brian n8wrl
I guess that it is a reflection of the very tight integration between the client (SSDR) and server (radio) that Flex has achieved. You have to think about it to realize where one starts and the other leaves off!
- 636 The Flea Market
- 143 SmartSDR+
- 261 SmartSDR CAT
- 199 DAX
- 45 Aurora
- 957 Maestro
- 57 FlexControl
- 931 Genius Products
- 302 Shack Infrastructure
- 141 Amateur Radio Interests
