WSJTX (Mac OS) no RF power after some transmissions
Dirk Schuurs
Good day,
Using SSDR for Mac and I like the FT8 tool, but unfortunately it’s not working together with GridTracker. So I installed and configured WSJT-X, which is working excellent together with GT and MLDX. BUT, after some transmissions (let’s say after 5 minutes) there is no RF-power and have to force to shutdown WSJTX and then start it again. Does anyone know what causes the loss of RF-power (although the Flex goes into transmission….)?
Thanks in advance,
Dirk HB9GPN
Thanks in advance,
Dirk HB9GPN
Do you have an audio out signal from WSJT-X after this short time?
Had the same problem with WSJT-X on MacOS Ventura, loss of audio output, after a few minutes. It was a known issue and discussed in the WSJT-X mailing list. I switched to JTXD for now and sometimes use the internal FT8 tools in SmartSDR.
73 HB9HJQ, Christian
Saw this on the WSJT-X manual for 2.6.1:
"If you are using macOS with an external audio device and find that Tx audio spontaneously switches to the motherboard sound device after a few transmissions, try setting the sample rate to 44100 Hz rather than the otherwise recommended 48000 Hz. "
HB9HJQ, thanks for the tip Christain: installed JTDX and all is working perfect now and works also needless with MacloggerDX. Also, problem solved :)0
- 634 The Flea Market
- 135 SmartSDR+
- 198 DAX
- 42 Aurora
- 956 Maestro
- 299 Shack Infrastructure
- 211 Networking
