17 Meter FT8 Frequencies
I see conflicting information on the clusters regarding allowable transmission modes on 17 meters. Per the 3Y0J facebook page: 18.112 MHz FT8 Fox/Hound
Someone posted :"IARU Region 2 allows 18111 to 18120 ALL modes"
However, FCC Part 97 shows this:
(https://www.ecfr.gov/current/title-47/chapter-I/subchapter-D/part-97 )
I hope that helps.
For the US above 18.110 isn't allowed. The last I checked, they were on 18.106.
Yes, that is what the Part 97 snippet shows.
3Y0J was operating FT8 on 18.112. At least that what all the spots showed.
Was that really him or a Pirate?
Who knows???
The frequency was correct as noted by one of the US pilots:
Apparently the first log uploads will be this weekend when back on Marma.
From EU, we could hear 2 stations with the call 3Y0J on 18112. One on even and one on odd. The one on odd was very strong with 3 streams which made me believe it was a pirate. But the logs will tell the whole story, once we get to see them. Late into the EU night on 30m, it was obvious a lot of USA stations were not using F/H and I see that Steve Hass has already confirmed that those stations are not logged. He has also been asked to pass on that USA needs the 3Y to be FT8 well below 18110 for 17m to conform with your regs. So hopefully they will now keep to 18106 as James witnessed.
Well, I beleive the Fox always transmits in the even slot.
Is that not the case?
Yes Geoff. There is a way around it which I am not going to describe here. But I am sure 3Y0J wouldn't do that and it cannot be done accidentally in WSJT-X. The doubt seems to arise from 3Y0J also one day on 21105 odd making people believe that they can and are using odd in multi-stream MSHV mode. But Steve Hass asserts that only F/H is used and, as you say, that means the even slot.
Thanks Erik
- 379 Community Topics
- 634 The Flea Market
- 139 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 270 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
