Cannot Change Com Port Number
ricka47
Member, Unconfirmed ✭
I installed Smart SDR today, and I note that two virtual serial ports were created COM115 and COM215. I tried to edit the CAT number to something lower but I cannot do so. Any ideas how this can be done?
Select the port you wish to edit, select edit, then right click in the edit window and select advanced.
Available ports should be in the drop down lists..
AL, K0VM
If you are up to 215, it sounds like you need to clean up a lot of unused ports.
This might help
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
