Remote output failure
I run a flex 6400 current v3239 software remote. Now about every 2nd connection I get no power output on tune. Ssb shows modulation but no power out. CW DOES have output power in tune. To fix this I need to reboot the radio remotely. It works as long as I am active but next day it might happen again if radio left on…. Any explanations out there??? Thanks
Hi Barry,
latest version SmartSDR is 3.3.33 and 3.4 is not far away. You can try 3.3.33 to see if it helps.
I have the same issue with IOS access, so it seems software independent.
But if you are using 3.2.39 then radio has 3.2.39 loaded.
you need to load 3.3.33 from PC to upgrade radio. And follow the release notes instructions.
Dave
Here’s the release notes
Ok… I get it… I’ll do that update and see what happens.
Were you able to fix the issue with the power. I have the same problem. Thanks....73 de IN3DOV
- 633 The Flea Market
- 130 SmartSDR+
- 197 DAX
- 41 Aurora
- 955 Maestro
