Is there a Bug on 6600 with 3.3.33 on Preamp/ATT?
DD2ML Ulli
Member ✭
Hi folks,
I have a brand new 6600 and found out a little strange thing with Preamp/ATT on ANT2.
It´s independend of used OS, so same on Maestro, Windows and IPad/IPhone.
We have a automated 6x2 Antenna switch on ANT2, all Monobanders with Bandfilters and a Multiband Vertical on ANT1.
Most used is ANT2 connector.
If we switch on the radio with activated ANT2 and then switch to - or + dB steps, the RX goes totally deaf as there is no antenna connected.
Then switch to ANT1 and any step of Preamp/ATT and all is working as it should, switch back to ANT2 and this also works now until the next reboot of the radio.
Any suggestions?
Any suggestions?
I doubt this is a software bug. If it was, thousands would be reporting the same problem.
I did open a support ticket for you. They will likely first ask you to reset your radio to see if the problem goes away.
- 391 Community Topics
- 665 The Flea Market
- 165 SmartSDR+
- 446 SmartSDR for Mac
- 208 DAX
- 387 SmartSDR API
- 65 Aurora
- 304 FLEX-8000 Signature Series
- 978 Maestro
- 868 FLEX Series (Legacy) Radios
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 826 Peripherals & Station Integration
- 145 Amateur Radio Interests
