Correct wiring/cable for 6400 to MercuryAT?
Nathan_KI4KM
Member ✭
I have read the combined pdf for both flex usb cables. The MercuryAT has a 3.5mm TRS connector. The MercuryAT manual has wiring schematics for Icom and Yaseu interfaces. I believe I need the flex USB to serial cable to build a control cable rather than the parallel cable. I understand that the pin layout and other aspects of the flex cable will be definable via software. I have searched and read on the forum extensively, but haven't found the specific solution.
I need the smartsdr tune button to activate a tuning call on the MercuryAT. Any help getting the correct cable for my usb port and settings in the software is appreciated.
The Mercury AT does not support Kenwood or Flex CAT protocol. Flex CAT commands are Kenwood format.
Thanks very much! I can live with that. The internal ATU unit works great on my antennas. I'll be operating remote on the flex frequently in the future and probably prefer no amp while remote anyway.
Thanks again, very helpful info!0 -
If you have a high SWR you will need a tuner after the amp.
I think you misunderstood my comment. Since I won't be able to use the MercuryAT and amp I will be limited to the transciever power only on remote. It's likely my preference to only run the transciever with no amp while remote.
Thanks again for your replies.0 -
I am not familiar with the Mercury AT. Can it operate in an auto mode to tune on carrier or with a PC based app to initiate a tune?
Maybe ask the question in the Mercury support group.
One other thought is to convert the Flex CAT (Kenwood protocol) to Yaesu CAT to Mercury tuner. The way I would do it would be with a Pi and Node Red to take Flex TX frequency and format it to Yaesu format and send to tuner.
Just some thoughts to try and help you out.
That's very much. I'm at the start of the research cycle on this, so your input is welcomed. I'll continue down the rabbit hole.0
- 375 Community Topics
- 105 SmartSDR+
- 425 SmartSDR for Mac
