When is Launch DAX and CAT
1. Do I need to launch DAX an d CAT to use the FT8 tool?
2. On DAX transmit what is the imput device? (options like intertnal mic, externa, mic... dont really make sense. The input device really is the SDR app but tht is not listed.
thanks in advance.
If you are using the built in FT8 tool you don't need to worry about launching DAX/CAT or any input/output settings. The software does all of that for you. You only need to worry about the DAX/CAT is if you decided to use external applications like WSJT-X or similar.
Good Luck with the software.
Michael, AA5SH
Michael, Thanks. Do you happen to know what "input device" is choose on the flex Radio side. The problem I am having, I think, is that no audio is being sent from FT8 tool to the SDR app. ft8 is triggerig transmit but nothing is being sent since it looks like no audio stream. Just as an aside when I select my input device as the built in apple mic and just talk I do get power and SWR activity on the radio. So it seems to me like FT8 isnt sending audio correctly. Thanks AO0
If you are using the built in tool there is no need to set an input/output device. Only thing to check would be to make sure the DAX button is pressed in the TX Panel. As well as the power slider. But typically all I ever had to do hit the RX button in the FT8 tool to start it up and then when click on someone or hit call CQ. Only thing I adjust is just the power slider to set the appropriate power level.
I am having the same problem AW0SHA describes after FT8 working fine for some time. Then one day I fired up the rig and no transmit power on FT8. Anyone else have the same issue, and if so, how did you finally resolve it?0
hi
when running macssdr and using the built in FT8 mode, need to select a dax channel and need to select TX in FT8 panel
also need to set power level
paul K3SF
then it is easy to make a contact
Thanks Paul,
Turns out my problem was with the firewall settings that changed when I installed Sonoma. Once I adjusted those settings I was back in operation. Marcus tipped me off to the issue some are having with Sonoma firewall settings.
aw0sha0
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
