SmartLink Test Fail
Dave
Upgraded to 3.3.33, Win 11. Test Fails. SmartLink reports configured. I've tried automatic and manual. Set manual to the recommended defaults 4994/4993 and let it set it's own as well. 21019/22028. The test reports UPnP ports TCP = FAIL/UDP = FAIL. Same for Forwarded Ports. Hole Punch Supported: No.
It use to work. Connected directly to the mode.
I rarely use SmartLink; however, it has worked in the past. The upgrade may not be related to the failure.
I have created a support ticket for you.
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 60 Aurora
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
