Output Power Question
Okay, so I was seeing what I believe is an inconsistency regarding the o/p power of my station.
QUESTION: Why are the o/p power readings after the PGXL in STANDBY different / larger than the o/p power readings into the PGXL from my 6600M?
SETUP:
6600M ==> LP-500 CH2 ==> PGXL ==> LP-500 CH1 ==> TGXL ==> AG OUT A
MODE is CW and PGXL is in STANDBY
TESTS:
Power Set .. LP-500 CH2 .. LP-500 CH1
12% 11.9 18.3
15% 15.0 23.0
20% 20.3 31.1
25% 25.2 38.6
30% 30.2 46.4
100% 103.0 162.0
The TGXL is showing accurate readings and are similar to the LP-500 CH2 readings.
A review of the FRStack Meter Window shows readings similar to the the LP-500 CH2 and TGXL readings.
Is there an issue with the PGXL? Maybe the LP-500?
I'm going to try a few more test ...
Swap the LP-500 couplers around and see if there's an issue there ...
After swapping the LP Couplers and checking the in and out connections, it looks like the o/p power from the 6600M, as shown from CH1 of the LP-500 are higher than what is being shown on CH2.
The MODE is CW, PGXL is in STANDBY.
CH1 = Output of 6600M between 6600M and PGXL
CH2 = Output of PGXL between PGXL and TGXL
12% into CH1 shows 19.8W into PGXL, CH2 shows 10.9W, RFStack shows 11.2 and the TGXL shows 12
15% into CH1 shows 24.4W into PGXL, CH2 shows 14.1W, RFStack shows 14.2 and the TGXL shows 15
20% into CH1 shows 33.0W into PGXL, CH2 shows 19.1W, RFStack shows 18.7 and the TGXL shows 20
25% into CH1 shows 41.0W into PGXL, CH2 shows 23.8W, RFStack shows 23.4 and the TGXL shows 26
30% into CH1 shows 49.4W into PGXL, CH2 shows 28.6W, RFStack shows 28.1 and the TGXL shows 30
100% into CH1 shows 171.0W into PGXL, CH2 shows 100.0W, RFStack shows 98.6 and the TGXL shows 104
So why are the power out readings of the 6600M into the PGXL through the Channel 1 coupler show higher values than those coming out of Channel 2 for the PGXL ... AND ... the TGXL is showing the values expected?
I get similar values after swapping the couplers.
SOLVED !!!!!!!
It was the SETUP in the LP-500 for CH1 .... I had selected the WRONG coupler for CH1 ... I had a 502 coupler selected not a 501
DUH!!!!!!!
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
