"micaudiodax.sys" driver cannot load on Win 11
While installing SmartSDR 2.8.1 on a new Dell PC running Windows 11 Home (22H2) I received the below notice on reboot. Is this driver necessary for DAX? How do I get it installed, if so? T
73, Duane AC5AA
  • Duane_AC5AA
    Duane_AC5AA Member ✭✭✭
    Answer ✓
    OK, found the right key to getting to the correct Windows Security window - there appear to be at least two of them. Here's the secret key:
    • From the search box, enter "Windows Security"
    • open the Windows Security APP that is pointed to
    • Select Device Security in the left column
    • Select Core Isolation Details
    • Turn the Memory integrity slider left to the "off" position
    • You will be prompted to reboot - do that.
    Now the driver runs but I'm running with lower protection against trojan horses. I will be openin a ticket for Flex to fix the drivers.
    Thanks, everyone, for your help.
  • VE7ATJ_Don
    VE7ATJ_Don Member ✭✭✭✭
    I think this is related to a Win11 security feature called 'Memory Integrity' (see Settings/Privacy and Security/Windows Security). When this is turned on, the DAX drivers have difficulty being installed (at least on my computer). And if you turn it off, then install 2.8.1, then attempt to turn it back on, then all sorts of nasty messages show up.
    I think it's a compatibility issue with the DAX drivers and this 'new' feature of Win11.
    I have the Memory Integrity setting on my PC turned off for the while, until this gets resolved. I haven't had any security issues with the PC.
  • Duane_AC5AA
    Thanks, Don - I'm going to adopt your approach. Thanks also for the quick response.
    73, Duane AC5AA
  • Duane_AC5AA
    Quick question, Don - how did you turn the Memory Integrity off? I find the Device Security link in the Windows Security setting window but neither it nor the "Open Windows Security" button do anything (other than indicate that I've clicked on them.) Right or left click = no response.
  • Trucker
    Trucker Member ✭✭✭✭
    You may have to open that feature in Administrative mode to be able to change it.
  • Duane_AC5AA
    Thanks, James - ,y account has Adminstrator privileges. I'm wondering if somehow Norton's software has something to do with disabling it . . .
  • VE7ATJ_Don
    Hi Duane... On my PC, I go to Settings/Privacy and Security/Windows Security/Device Security and I get the following screen:
    Note the slider switch for Memory Integrity. Depending upon how you set up your PC, this may already be 'on'. On mine, I had SmartSDR already installed when I upgraded to Win11 (I'm pretty sure, anyway) and this may have inhibited it being turned 'on'. If you have Win11 installed before installing SmartSDR, this may be a problem. If your case is the latter, I would suggest opening a Help Desk ticket to get the Flex folks to give you a hand.
    The other option... if you don't need DAX, you could just not install that when you install SmartSDR....
    Hope this helps..
  • Trucker
    Trucker Member ✭✭✭✭
    Duane, that could be a possibility. I am running a refurbished Dell pc with Windows 11 pro that I bought from a local pc shop. I haven't (so far) encountered any DAX or CAT problems with SmartSDR. I am running SmartSDR v3.3.33. Also running an older pc I built years ago with Windows 7 pro. I wouldn't be surprised if your anti-virus or firewall is causing the problem.
  • Duane_AC5AA
    OK, just to try to isolate the issue, I uninstalled Norton 360 and the DAX driver still failed to load with the same information message. Additionally, with my account's "Administrator" privilege verified, I could not get into the "Device Security" entry to disable the Memory Integrity. I get this far, and nothin happens when I click those areas other than the selection "depresses" as if it's going to initiate the operation, but nothing happens. (Yes, I rebooted after the Norton uninstall!). Time to open a ticket and see if someone at the mother ship can help.
    Thanks for all the suggestions - was hoping to be able to get on for the FT8WW on a digital mode, and of course be ready for Bouvet Island!
  • Duane_AC5AA
    This is what I see when I get to Windows Security
  • VE7ATJ_Don
    I know you have this solved, Duane (thanks for the DM!), but for others...
    From this point (your screenshot), click on the Open Windows Security button. Then select Device Security. Then you should see the screen I showed.
  • Duane_AC5AA
    What happened to my follow-up? As I noted earlier, at the screen above clicking "Open Windows Security" does nothing. I found the way I had to go in was as follows:
    • Search "Windows Security", and open the APP (no other path works for me on the current Win 11 build)
    • Click on "Device Security" (either in the left column, or the icon for it)
    • Under Core Isolation, click on "Core isolation details"
    • Now, on the Core isolation screen, slide the "Memory integrity" toggle off (to the left)
    • The system will need to reboot, but that should do it.
    I hope this saves someone else a lot of time!
  • Will there be a fix to this driver at some point so that we do not have to turn off Memory Integrity on a Secured-core PC?
  • k5gtx
    k5gtx Member
    I have this issue now on a new Windows 11 NUC Dev Channel Build.
    I echo the request for a fix. In today's environment I would prefer to not have to turn off Memory Integrity!
  • SV1RXI
    SV1RXI Member
    edited February 8
    when i tunr it off to don't have this message ,now i can't turn on again memory integrity.I was able to delete them from device manager .To my laptop no problem ,maybe there was first w10 and upgrade to w11 ,but to my pc was clean install to w11
  • rdwing
    rdwing Member ✭✭
    I have been asking for this to be resolved for years and years, like at least 4 years now. We are fast approaching the day when you will not be able to disable memory integrity, not to mention it is degrading the security of the entire sytem.
    Many other driver makers have gotten their act together, when will FRS?
  • aa1ffradio
    aa1ffradio Member ✭✭
    I have never seen a company so slow to correct software issues. Just like the new subscription model. Paid $300 for 30 day advanced access to for new features in December. Almost 3 months later and nothing. 25% of my advanced feature subscription is almost used up and NOTHING from Flex. This has been the problem with them since the early days of Smart SDR. SLOW SLOW SLOW rollouts of fixes and features. But they're taking peoples money for it.
