PGXL v3.7.28 - Nickname
Mike VE3CKO
Member ✭✭✭
Installation went smooth as expected. The remote operators are going to love this update. Unfortunately I'm one on those on a double NAT so SmartLink can never be used.
I found a very minor thing, I did notice that the radio Nickname has the last character cutoff, see below. In my case it is 11 characters VE3CKO-6700. Previous versions did show the full 11 characters.
2
I created a ticket for this for you Mike. 73
After the update some characters on the display disappear before you saw Flex-B-6400 now you only see 640 and when I transmit in CW it protects itself since it tells me that it has High SWR and the power display varies from 100 to 300 or 400w it seems to be there Something to fix. Is it possible to download my version again?
TRY doing a Power down and if that doesn't work then do a hard reset and see if that helps, mine shows the full name from the Radio's just fine (9 characters), Of course it could be Limited to 10 characters.
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
