Flex 6600m ATU
Is there any way to disable the ATU being I have ATU built into my amp I can't find anyway in menus to disable I cut off manually on front of radio but every time I change frequency or change bands it comes back on
  • Steven WA8Y
    Steven WA8Y Member ✭✭
    edited December 2018
    Yes, mine is always BYP for the same reason.  TX control window, right side.
  • Jimmy Collis
    Jimmy Collis Member
    Thanks Steven i went to the window on the pc screen i was looking for it on the radio not connected to the pc working fine bussiness now thanks again for the info
    73 es gud dxing
  • Peter DK6HQ
    Peter DK6HQ Member
    Steven, push the Mic-gain button and disable ATU MEM. The internal tuner will stay off now.
    edited April 2019
    Correct.  Turn off ATU Memory
  • terry
    terry Member ✭✭
    edited July 2019
    Thanks...
  • Vin Jacobo
    Vin Jacobo Member ✭✭
    [{"insert":"The ATU on my 6600m , running version 3.3.33.10471, tunes the antenna on port 1 but does not reach on tune on antenna port 2 (even if you connect the same antenna). I have opened a ticket but was wondering if there is a quick answer / resolution here. I would appreciate any help.\nThanks\n\nWZ2J\nVin\n \n"}]
  • Neil D Friedman N3DF
    Neil D Friedman N3DF Member ✭✭✭✭
    You have made the antenna on port 2 the transmitting antenna?
