Stream deck / FR stack FR Stack running on remote computer.
Is it possible to have FR stack running remote and point the stream deck to that computer that is remote giving you have the firewall port open etc. Reason I ask so far I can't get it to work that way and just wondering if I am doing something wrong. I have a dynamic DDNS running and all of that checks out. I also have the port 13522 opened and pointed to the FRStack computer
Thanks in advance.
Brad
k9bdh
You left out these steps, outlined in the FRStack REST Help file.
Alan. WA9WUD
Calling REST API from other Clients
The REST API are restricted by default to Localhost. This can be change by editing the FRStack.exe.config file.
Set the <add key="LocalHostOnly" value="false"/> which allows other clients to call REST APIs.
By default any client can now call the REST APIs. You can restrict the clients to by their IP address.
Set the <add key="WhiteListedIPAddresses" value="192.168.1.123,192.168.1.124"/>
Note : If FRStack is running as a User and not Admin, access is denied to http.sys. To solve:
run FRStack as Admin OR
config access by running as Admin: "netsh http add urlacl url=http://+:13522/ user=everyone delegate=yes""
Make sure you create an inbound TCP Firewall rule for your REST API port, 13522 is the default port.
FRStack support using SmartLink to connect to the radio.
I gather you need this for some other features?
When I run remote I run FR stack remote at the radio site. I want to use my stream deck remote on windows smart sdr. When I use Mac SDR its no big deal as i have all the MIDI commands set up but windows I don't think you can use the commands direct to windows smart sdr
I run SmartSDR for Windows, FRStack and Stream Deck remote on a Dell XPS laptop. I did a demo of this back to my home station from Xenia this year.
- 387 Community Topics
- 438 SmartSDR for Mac
- 203 DAX
- 385 SmartSDR API
- 52 Aurora
- 969 Maestro
- 944 Genius Products
