How does one monitor the spectrum of the PGXL output?
    Answer ✓
    The other way is to use the -60db tap on the back of the PGXL and then monitor it with a Spectrum scope/analyzer.
  • David Decoons, wo2x
    A spectrum analyzer is one way.
    Hi Doug, depending on what you are trying to do, it can be as simple as opening a web SDR and looking at your signal there. If you are trying to do quantitative signal analysis, then Dave's answer is probably what you need. Just be very careful not to over drive the SA.
