Flex 1500 Headphone Jack Part #
Max_VE3TMT
Looking to replace the headphone jack on my 1500. The plug is not clicking into place as it should. I've downloaded the service manual, but it does not list the parts BOM.
Any help appreciated.
Thank you,
Max
VE3TMT
Thank you,
Max
VE3TMT
I would imagine that you could find a replacement jack from several sources as long as it has the same mounting as the original. I have never seen a parts list for any of the Flex radios.
[{"insert":"I guess I would have to pull it from the board and take some measurements. I was hoping to avoid this. \n"}]0
Look at it this way...after you remove it the job will be half done!
[{"insert":"I guess I would have to pull it from the board and take some measurements. I was hoping to avoid this. \n"}]> @"Geoff AB6BT" said:
Good point Geoff. I'm assuming it is a standard part. I did look through DigiKey's offerings and there is a selection of which I am sure one would work.0 -
Mouser is another good source. Sometimes the two have stock from different manufacturers.
Good luck.
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
