What is wrong with my ZeroTier Set-up?
Kari Gustafsson SM0HRP
I have installed Zerotier with a plug-in in my 5G router (Teltonika). Then as follows:
- Registered a ZT account.
- Got a ZT Network ID and connected my router, PC and Mac OS to the network.
- According to Router Manual I just then assign a managed route (192.168.1.0/24) to my Router via the ZT IP 10.27.x.x.x .
- Then if I try to connect via web browser (10.27.x.x.x) to the router IP 10.27.x.x.x I should access all LAN devices (Flexradio, webrelay, PGXL etcetera). But I never get a "you are now connected to LAN 192.168.1.X or similar. Trying to ping my router does not get an answer.
Am I missing something? I add the pics from the manual.
Kari, in my working setup on a Raspberry Pi as the Bridge (Layer 2) device, the ZT network and Internal network are on the same subnet, in my case 192.168.1.0/24
My internal DHCP Server assigns IP's from 192.168.1.2-199 while ZT assigns IP's from 200-229 to the ZT Client interfaces
Also, make sure your Bridge device is configured like this
Official ZT Bridge documentation https://zerotier.atlassian.net/wiki/spaces/SD/pages/193134593/Bridge+your+ZeroTier+and+local+network+with+a+RaspberryPi
Hope this helps.
Roland
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
